mik60ish Posted January 1, 2010 Share Posted January 1, 2010 I have just bought a 2nd hand Dellorto that was from a Fantic 125, it wouldn't run properly the existing jets are 95 main 45 pilot had a job to read needle 22!. Has anyone running a Dellorto and could inform of their jetting success ? Quote Link to comment Share on other sites More sharing options...
alan Posted January 1, 2010 Share Posted January 1, 2010 (edited) I am sure that some one will be along soon to give you the jets etc, but are you aware that the two stroke carb uses a different emulsion tube too ? www.ducatimeccanica.com/dellorto_guide/dellorto_3_6.html Edited January 1, 2010 by alan Quote Link to comment Share on other sites More sharing options...
gii Posted January 1, 2010 Share Posted January 1, 2010 I borrowed one from a mate, it worked great on his but poorly on mine. The settings are as advised by Eurocarb, the dellorto importer and are: Pilot 35, Slide 40, Main 100, Emulsion BZ260, Needle D40 middle groove, Eurocarb can supply you all of the bits, just google dellorto uk Quote Link to comment Share on other sites More sharing options...
superhondaman Posted January 8, 2010 Share Posted January 8, 2010 What size is it? anythjng bigger than a 22mm will run pants Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted January 8, 2010 Share Posted January 8, 2010 Hi Guy's. Ask Bob. He will sort you out.http://www.upbuk.co.uk/pre65.html. Regards Charlie. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 8, 2010 Share Posted January 8, 2010 Hi Guy's. Ask Bob. He will sort you out.http://www.upbuk.co.uk/pre65.html. Regards Charlie. Try www.upbuk.co.uk/pre65.html Quote Link to comment Share on other sites More sharing options...
superhondaman Posted January 11, 2010 Share Posted January 11, 2010 PHBL 20 40 slide d40 needle b2260 atom 9.5 float 45 choke 35 pilot 2.5 turns out 118 main Quote Link to comment Share on other sites More sharing options...
