manx2day Posted January 8, 2010 Share Posted January 8, 2010 (edited) I discovered the other day that the top mounting bracket on my rear brake master cylinder has broken clean off, which was annoying! Luckily there are many trials coming up anytime soon so it's not a huge problem! Do you think it can be welded back on or is it not worth the hassle of it potentially breaking again and again, in which case a brand spanker would be better. Personally, I think a new one would be better in the long run but, if it can be welded and guarenteed that it won't break again i might go for that. Anyone know how much a new one is? Cheers Edited January 8, 2010 by manx2day Quote Link to comment Share on other sites More sharing options...
mikee Posted January 8, 2010 Share Posted January 8, 2010 I bought a new one not that long ago and it was about fourty quid all in with post and vat. You could get the broke one welded up and use as a spare,,,but i would put a new one on just to be sure. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 8, 2010 Share Posted January 8, 2010 I discovered the other day that the top mounting bracket on my rear brake master cylinder has broken clean off, which was annoying! Luckily there are many trials coming up anytime soon so it's not a huge problem!Do you think it can be welded back on or is it not worth the hassle of it potentially breaking again and again, in which case a brand spanker would be better. Personally, I think a new one would be better in the long run but, if it can be welded and guarenteed that it won't break again i might go for that. Anyone know how much a new one is? Cheers Did it break because you hit it, or are the mountings not in line putting stress on the bracket ? If the latter, you will need to align the mountings or pack as required to stop this happening again. Quote Link to comment Share on other sites More sharing options...
manx2day Posted January 8, 2010 Author Share Posted January 8, 2010 it broke after landing upside down after a crash. Oops! Quote Link to comment Share on other sites More sharing options...
