Rl250 Beamish Con Rod
hello, can anyone advise me where to get a con rod kit for a silver engine RL250 beamish .
have tried one suzuki dealer with no luck, and four other suppliers of pattern parts.
two of the suppliers had con rods but both turned out to be the wrong part when delivered (very annoying!)
somewhere in the south east of england would be best so i can drive there and see if the part is
correct before i pay .(and can avoid the messing about involved in returning parts)
alternatively would any body know if the TS250 or TM250 from the early 1970`s (or any other models)
use the same con rod ? this would give me another option to try when looking
thanks in advance for any help
dave
Gday, according to my cross reference the 74 RL uses a 12161- 30200 Rod, same as a TS 250 69-74 model, and a 72-74 TM 250. The 75 RL uses a 12161-16400 rod, same as 72-75 TM 250, and TS 250 71-81
(up to an X) 250. It looks a bit like there was supercession there. I Dunno if the Beamish's used a different rod. Pro-X have a sizing chart in their catologue and Im sure they would make a rod that fits.
Cheers,
Stork
thanks Stork , for that information, it will give me some more options to look for.
i am not sure the exact year of this beamish , from what i have read about them they are not
an easy bike to date . I think it could be between 74-78
thanks
dave
If you are struggling obtaining a genuine Suzuki con-rod it may be worth trying Kevin Breedon Racing, I have found them really helpful.
Accurate measurements or sight of your existing rod may be required but definitely worth a try.
http://kevinbreedonracing.co.uk/index.htm
  • 2 weeks later...
