Rear Brake Hub M-80
myson
Hi, I have the rear wheel out of th bike and I have some questions about the brake hub. What is the correct internal Dia (Mine has a slight lip then is a chamfer to main braking surface, it measures 140mm on lip but I cannot get measurement beyond this as I only have a vernier not an internal Micrometer) Next what should the surface look like and is it a replacable liner or an integral part of the hub. If necessary can it be relined easily? Finally what thickness is the brake shoe when new so I can judge wether replacement is due?
Cheers
If it rusts it will be a liner, if there are any shiny flaky bits its crome and probably due fora re-line.
I use a dremel type thing to get rid of the lip, makes it easier to get the shoes back in.
Edited by B40RT
Thanks everyone, its definitely an M-80 and there does seem to be some signs of rust developing whilst it has been standing. I will try to post decent photo for clarification,
Graat advuce as usual,
Cheers
It depends on how serious you are about having good brakes
If the drum diameter where the shoes run is different to the diameter of the shoes when they are on the backing plate, the contact area will be small = poor brakes.
Standard shoes + worn drum = poor brakes
Oversize shoes machined down to worn drum diameter = slightly better brakes
Oversize shoes machined to fit + skimmed flat drum surface = great brakes
Resleeved drum + shoes that match diameter = great brakes
The picture is out of focus so impossible to tell if it is worn too far for skimming or requires a new sleeve.
Cheers for that. I have contacts in several CNC companies that could skim or re sleeve for me. How do you secure sleeve to prevent slippage and what material would you recommend?
I believe correct ID is 140mm is that about right?
Thanks,
Myson
