Gas Gas Gear Lever
Hi,
Whats the best option for refitting the gear lever with a flywheel weight? Obviously the lever doesnt go fully on the shaft due to the extra width of the flywheel cover, previously I have bent and filed a bit off the back of the lever, but it never seems to go right on the shaft.
I was just wondering what others do?
I have noticed my flywheel kit has a 10mm cover spacer (its an unknown make that is held on with a hollow nut threading into the puller threads on the flywheel) wheras my friends Hebo kit has about a 7mm cover spacer so I may try his cover on to see if it clears my flywheel and try to buy a hebo spacer if you can buy them separately?
Ian
I have an 'S3' weight, it's fitted with 2 countersunk screws and the cover spacer is only 6mm, the lever will just about go fully on the shaft with no clearance so I pull it back 1mm.
