76ty175 Posted May 6, 2010 Share Posted May 6, 2010 (edited) Just found this one. I have removed the seats and tank. The tank has lots of rust inside. Is there any way to save it, maybe a coating or something? Anyway its a long term project, my goal is to use this one for comp and keep my other one, which is 100% stock and original, as a looker. Edited May 6, 2010 by 76TY175 Quote Link to comment Share on other sites More sharing options...
squid Posted May 6, 2010 Share Posted May 6, 2010 Yes,I've just restored my tank last week. The product I used is called restom and it works a treat. Its a 3 stage treatment. 1st product degreases 2nd one gets rid of the rust and the 3rds a resin to seal it. I've used it before and its brilliant. Iam in france but Iam sure you can get it else where or another manufacturer. Quote Link to comment Share on other sites More sharing options...
alan_nc Posted May 6, 2010 Share Posted May 6, 2010 I have used both POR15 and Caswell's. Had no problems with either(I would avoid Kreem, I've had cracking problems with it). Make sure and follow the directions exactly and clean out the inside of the tank prior to the coating process. I mount the tank on a rotissary grill, put in a couple of hand fulls of bolts or stones, some dish washing soap, little water and let it rotate for 10 to 15 hours. Might need to change the mounting of the tank a couple of times to make sure all areas get cleaned. Usually comes out looking almost new. Great find, should be a lot of fun Alan Quote Link to comment Share on other sites More sharing options...
76ty175 Posted May 6, 2010 Author Share Posted May 6, 2010 (edited) Thanks for the info, I'm looking forward to this rebuild. The rotissary id is great, would have never though of that. Edited May 6, 2010 by 76TY175 Quote Link to comment Share on other sites More sharing options...
squid Posted May 7, 2010 Share Posted May 7, 2010 Check this out http://oldbikehack.blogspot.com/2010/01/ho...-rust-tank.html Quote Link to comment Share on other sites More sharing options...
76ty175 Posted May 7, 2010 Author Share Posted May 7, 2010 Squid, Thanks for the link. Just got the carb off for a cleaning, I mite be able to save it. Checked the spark and it looks strong. So should be able to get it running soon. Quote Link to comment Share on other sites More sharing options...
76ty175 Posted May 8, 2010 Author Share Posted May 8, 2010 Got the carb sorted out, new plug and fired right up. Tad bit loud without the sparkie but the engine sounded great, rev up. Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 12, 2010 Share Posted May 12, 2010 Glad it still runs , Bob Quote Link to comment Share on other sites More sharing options...
76ty175 Posted May 12, 2010 Author Share Posted May 12, 2010 Thanks Bob. Quote Link to comment Share on other sites More sharing options...
76ty175 Posted June 19, 2010 Author Share Posted June 19, 2010 Got the old girl stripped down and ready for paint. Don't know if I will go with silver or white. Leaning towards white just to be a little different. Quote Link to comment Share on other sites More sharing options...
76ty175 Posted July 2, 2010 Author Share Posted July 2, 2010 White it is, just ordered MS pegs and IRC tires. Engine is almost ready to reinstall. Quote Link to comment Share on other sites More sharing options...
ty_steve Posted July 2, 2010 Share Posted July 2, 2010 Hey - it looks great! Did you spray the fenders and plastic autolube oil cover as well? Quote Link to comment Share on other sites More sharing options...
ducman Posted July 2, 2010 Share Posted July 2, 2010 Hey John, perfect job,IRC Tyers are a good choice. Chrs:Mike Quote Link to comment Share on other sites More sharing options...
76ty175 Posted July 2, 2010 Author Share Posted July 2, 2010 Hey - it looks great! Did you spray the fenders and plastic autolube oil cover as well? I used "KRYLON Fusion" which matched the frame really close, not quite as high gloss but works well. The fenders bend with out any effect on the paint. Quote Link to comment Share on other sites More sharing options...
