Some Interesting Questions!
billyt
Okay, a thought with some questions associated with it!
How many righties to lefties are riding trials?
Do the lefties have trouble with the right hand throttle?
What would happen if we installed a quad/four wheeler type thumb throttle to a trials bike?
Would this be nuts or start a trend?
Things that make you go mmmmm....
Edited by BillyT
As a left hander i've ocassionally wondered the same thing.
Whilst being left handed i'd also say i've never had a problem with a right handed throttle, but then again i'm no Dougie either- but doubt i can blame the throttle position for that one
Also, we have the advantage of operating the clutch with the favoured hand, does that cancel out and percieved advantage of disadvantages?
I suppose a poll of the top riders would be interesting, if none are lefties i'd at last have a bonafide excuse for being rubbish!
Cheers
I'm also a leftie and old enough to have ridden bikes with lever throttles;; suffice to say I'll stick with twistgrip. Your questions made me go mmmm in a happy memory way ;..we used to ride an old (Norton I think) with hand gear change on tank and lever throttle and some of the funniest crashes ever can be attributed to those controls, if only we had U tube etc back then, I remember we used to tow a sheet of corrugated steel (one half of an old anderson (bomb) shelter) around the field with several on board and the trick as the rider was to crash the lot of em into a fallen tree trunk by swinging it out like you see water skiers do. Ah no helmets no licences no health & safety... happy days.
I have an Expert-rated friend who has run a thumb throttle (old Kawasaki 220 four-wheeler type I think)
as long as he has ridden Trials. He has one on his new Pro. I rode his bikes and it allows a good grip on the
bars in the straightaway stuff, but I found it very uncomfortable when I had to move about in the tight stuff.
My wrist was at a weird angle when leaning off and it was difficult to use the throttle smoothly. He has no
problem with it, but that's all he's ever used since coming into Trials from quads.
The racing four-wheeler Quads I've built for the Pro's has almost exclusively used twist throttles rather than thumb
throttles as it makes it easier to move forward on full-lock in tight turns and modulate the throttle.
I imagine it's personal preference but I doubt thumb throttles will catch on. Imagine the wrist angle a WTC rider
would need to go up the front fender kissing walls they have to climb. As yet, the thumb throttle housings must be
stationary so you can't re-position your grip needed from downhill drop/slide to straight up wall climb.
Jon
Sorry guys. I can not get the font size to change in the edit function.
So why not switch the clutch hydraulic over to the right hand side master cylinder and the front brake hydraulic hose over to the left hand side master cylinder and then
take the throttle tube assembly from the right hand side bar position and install on the left hand side bar position.
You would have to make a new throttle cam to go the opposite way with this set up.
The advantage is that lefties can be more comfortable with the main control in their dominant hand.
So, lefties if you had a throttle cam available for this experiment would you try it?
Edited by Slapshot 3
It's amazing how font size has an emotional effect on reading one's post.
I would think you would need a new throttle housing to pull the opposite way, in addition to a new tube/cam assembly.
Another possible advantage is that it would be difficult for somebody to ride off on your bike, thou it would be fun to watch them try....
Jon
Jon
I cant get the font to change size! Sorry!
Yes as I stated earlier one would have to change out the throttle cam assembly.
Yes I agree and can see it now. Another rider jumps on your bike and there is no throttle to turn! ^_^
Many years ago one could buy a blank throttle tube with no cam on it. It is very easy to make if one wanted to try it!
Jon
I was just pulling your leg, no offense intended.
The standard housing is made to pull just one way and it would have to be designed to have the cam-stop on the opposite side.
I wonder how many lefties would like this, maybe a lot. I know they have stores devoted to everything left handed, like sissors and
can openers, why not a throttle housing? I agree, the rest of the controls should be easy to switch over. My youngest son is left-handed
and rides bikes a lot, I'll ask him what he thinks.
Jon
Why does a Left handed person have difficulty with the usual way a bike is setup? A Right handed person doesn't have difficulties with the usual left hand side clutch control? The clutch requires a sensitivity normally reserved for the lead hand (especially trials) but all Right handers seem to manage it all right.
As a Right handed person, if the only motorcycles I had ever ridden had the controls the other way round I'd most likely ride exactly the same as I do now (badly!).
One could argue which needs the most control, throttle or clutch? Who actually has the advantage? Maybe it's the clutch that benefits from ones "lead" hand?
Or have I got it all wrong? ^_^
