steveplum Posted August 17, 2010 Report Share Posted August 17, 2010 Just a quickie how do you tell what pilot jet is in the carb. I was at a trial the other week and the bike sounded like it was hunting. To cut a long story short, someone there spotted this and adjusted the mixture srew about 3.5 turns from fully in and suggested i get a 33 pilot jet as id prob be running a 30. I just dont want to buy a 33 if i may already have one in. Oh the bikes an 04 250 sherco All help appreciated!!! Link to comment Share on other sites More sharing options...
rlracer Posted August 17, 2010 Report Share Posted August 17, 2010 You take the pilot jet out and look at the number it has stamped on it. Link to comment Share on other sites More sharing options...
shercojay Posted August 17, 2010 Report Share Posted August 17, 2010 as above ^^^^^^^^ just watch when you split the carb the floats dont fall out Link to comment Share on other sites More sharing options...
tony27 Posted August 18, 2010 Report Share Posted August 18, 2010 No need to remove the jet, the number is stamped on the head in plain sight. Pilot jet is the jet towards the front of the carb closest to the main body Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 18, 2010 Report Share Posted August 18, 2010 There is a good possibility it may be slightly blocked so take it out anyway and blow it through with a air line. Link to comment Share on other sites More sharing options...
steveplum Posted August 18, 2010 Author Report Share Posted August 18, 2010 Thanks for all the help guys. I'll split the carb and give it all a good clean out. Ive had this prob before but it turned out to be the angled throttle guide tube on top of the carb that was snapped. Its suprising how little things cause problems. If the cleaning doesnt work is it adviseable to get a different pilot jet?? Link to comment Share on other sites More sharing options...
copemech Posted August 19, 2010 Report Share Posted August 19, 2010 Your advise is sound, yet you may indeed find you are on a 33 pilot, as a 30 makes things quite weak off the bottom. The fuels in many parts has changed over the years as well with the introduction of the ethanol(alcohol) blends. Many now run a larger 35-36 range jet on the later models, yet I cannot tell if this is purely a fuel issue or the year range of the bikes as I do not have an earlier model to directly compare. I ran a 33 nicely back in '03, yet my '07 2.9 was on a 38 prior to changing the carb to the Oko! Running the fuel screw out at 3.5 turns on a Dellorto is at the limits of its range of control. And on a Dellorto, the pilot jet also controls the transition circuit, whis is that totally unregulated(jet only) other little hole in the bore, so if your pilot jet is too big, even though you might be able to achieve a good idle with the fuel screw adjustment, it could turn a bit rich and blubber a bit at about 1/16 steady throttle during the transition to the needle. Back in the day, I had to go back to 32-33 range from 35 because of this. Add each bike and carb vary a bit, so no set rule here. My '07 was on 1.5 turns out with the 38, and worked perfect on our fuel! Adjust on the temps of the day, need more(out) when its cold. Link to comment Share on other sites More sharing options...
nigel dabster Posted August 19, 2010 Report Share Posted August 19, 2010 make sure the fuel filter is clean. Link to comment Share on other sites More sharing options...
steveplum Posted August 23, 2010 Author Report Share Posted August 23, 2010 Hi all took carb off gave it a good clean out found its already running a 33 pilot jet! Put it back on the bike and it continues to run the same thats with the mixture screw turned out 3.5 turns. Runs ok with choke on but cant leave that on when riding. Any suggestions??? Link to comment Share on other sites More sharing options...
shercojay Posted August 23, 2010 Report Share Posted August 23, 2010 air filter and box cleaned Link to comment Share on other sites More sharing options...
copemech Posted August 24, 2010 Report Share Posted August 24, 2010 Hi all took carb off gave it a good clean out found its already running a 33 pilot jet! Put it back on the bike and it continues to run the same thats with the mixture screw turned out 3.5 turns.Runs ok with choke on but cant leave that on when riding. Any suggestions??? Well, if you are sure the jets are clean, you could have an air leak. Specifically the crank seals, see recent post! Link to comment Share on other sites More sharing options...
shercojay Posted August 24, 2010 Report Share Posted August 24, 2010 you need to make sure that everything is clean, carb, airbox and filter like cope said it might be the crack seals, easy way to check is to spray some carb cleaner around the flywheel and look for it be sucked. how did you clean the jets ??? it sound like fueling to me Link to comment Share on other sites More sharing options...
steveplum Posted August 24, 2010 Author Report Share Posted August 24, 2010 I took the jets out and stuck a pin through them then blew them out with the air line. Not put a clean air filter in so will have to try that. Would a bigger jet not help or is a 33 adequate? My bros got an 07 125 cabby i could try swapping the carbs over and try that. I did that last time I was fault finding when I had the snapped throttle cable guide tube issue. Its frustrating when i dont have the knowledge on how it all works properly. Thanks again everyone for your inputs id be a bit lost with ou you Link to comment Share on other sites More sharing options...
nigel dabster Posted August 24, 2010 Report Share Posted August 24, 2010 I took the jets out and stuck a pin through them then blew them out with the air line. Not put a clean air filter in so will have to try that. Would a bigger jet not help or is a 33 adequate? My bros got an 07 125 cabby i could try swapping the carbs over and try that. I did that last time I was fault finding when I had the snapped throttle cable guide tube issue. Its frustrating when i dont have the knowledge on how it all works properly. Thanks again everyone for your inputs id be a bit lost with ou you what was the fuel filter like? Link to comment Share on other sites More sharing options...
steveplum Posted August 24, 2010 Author Report Share Posted August 24, 2010 The fuel filter seemed pretty clean it that got a blast out with the air line too when I had the carb stripped. what you thinking like? Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
