September 11, 201016 yr I have a Yamaha TY250 Twinshock around a 1974 -1975 it is in mint condition with only 500 miles on it. The bike starts no problem and sounds good it's only when riding and at 3/4 - full throttle that it seemd to start pinking and looses power. I've had the carb out countless times and cleaned it also checked the reed valves, air filter and the exhaust and there all fine someone mentioned it could be a timing problem but i'm not sure I love this bike but and want it fixed Anyone any ideas?????
September 11, 201016 yr The bike is 35 yrs old, with only 500 miles on it......maybe its done 15 miles per year, or maybe it did 500 miles in 1975 then sat around in garage. The point is the bike has done an awful lot of sitting around, not running, I wouldn't be at all surprised to find out it was a carby problem !
September 11, 201016 yr Author The bike is 35 yrs old, with only 500 miles on it......maybe its done 15 miles per year, or maybe it did 500 miles in 1975 then sat around in garage.The point is the bike has done an awful lot of sitting around, not running, I wouldn't be at all surprised to find out it was a carby problem ! Yip the bike is 35 years old i bought it when it had 300 miles on it from the origonal owner (friend of the family) and it ran great for a while with no problems. I have done some reserch and remembered that instead of using the seperate oil tank for the 2 stroke oil i have just been pre mixing the fuel and had the oil tank out of use. Now i'm thinking that i maybe suckin/ pumping air into the carb. Could this be so???????
September 11, 201016 yr Yip the bike is 35 years old i bought it when it had 300 miles on it from the origonal owner (friend of the family) and it ran great for a while with no problems. I have done some reserch and remembered that instead of using the seperate oil tank for the 2 stroke oil i have just been pre mixing the fuel and had the oil tank out of use. Now i'm thinking that i maybe suckin/ pumping air into the carb.Could this be so??????? Thats more than likely exactly what it is - try just blocking up the hole in the tank, then set your mixture accordingly, as this will remove air from the lower acceleration band, causing your mix to go off slightly.
September 11, 201016 yr On a bike that old and not ridden much, replace the crank seals, they must be hard and sucking air into combustion area.
September 27, 201016 yr You don't say what model this is. If its a TY250A then the oil is injected into the barrel directly on the right hand side. A simple bolt in this hole will fix the problem. If it is a later model then the oil was injected into the front of the carb and you will need a small blanking rubbber over this inlet. Other problems could be the needle clip position and the size of the main jet. Use a 150-160 main jet and set the needle clip on the central position. The timing on ALL of these TY's is a fixed stator plate so unless someone had modified it this will not move. Make sure you are using the correct plug (NGK B7ES) and set the gap to 22 thou and make sure the points are 15 thou. Tony
August 14, 20197 yr Author Extremely ate in my reply but all sorted it was a small O ring in the carb changed it out and running sweet now
August 14, 20197 yr 15 minutes ago, austin6728 said: Extremely ate in my reply but all sorted it was a small O ring in the carb changed it out and running sweet now I've been waiting on tender hooks for 9 years waiting for the outcome ??
August 14, 20197 yr Author 1 hour ago, b40rt said: I've been waiting on tender hooks for 9 years waiting for the outcome ?? And I fixed it in about 9 minutes ?
