bigwilly Posted November 20, 2010 Share Posted November 20, 2010 I've been running my ty on 25-1 since I got it though the last 2 times out it has taken a while to run right. Today it was a pig and I spent a whole bunch of time fannying about with plugs which leads me to beleive the mix I'm running is too rich. I know many modern trials bikes run leaner though am unsure what I should be putting in this. What do you guys and girls run them on? Quote Link to comment Share on other sites More sharing options...
chewy Posted November 20, 2010 Share Posted November 20, 2010 way too much oil Others will know exactly what the TY prefers but I would have thought more like 70 to 1 on synthetic or even a semi sythetic oil. Incidentally (it's logic that more oil means less actual petrol to detonate so it would actually run a bit lean regards air /petrol mix. Why not try 50 to 1 petrol/oil using decent oil and see if it improves. Quote Link to comment Share on other sites More sharing options...
badbowie Posted November 21, 2010 Share Posted November 21, 2010 Yeah I use Motorex and mix it at 50:1 in my Mono. Quote Link to comment Share on other sites More sharing options...
guy53 Posted November 21, 2010 Share Posted November 21, 2010 I run 2% ( 50/1 ) in my ty250a with good motorcycle oil and it is still a little ritch, but no fouled plugs and it start on 2nd kick cold and 1st when hot. If you have been running that mixture for a while, you will probably have to clean your pipe. Guy Quote Link to comment Share on other sites More sharing options...
marky g Posted November 23, 2010 Share Posted November 23, 2010 I run 2% ( 50/1 ) in my ty250a with good motorcycle oil and it is still a little ritch, but no fouled plugs and it start on 2nd kick cold and 1st when hot. If you have been running that mixture for a while, you will probably have to clean your pipe. Guy Always run my monos on 50/1 no problems at all Quote Link to comment Share on other sites More sharing options...
agp244 Posted November 23, 2010 Share Posted November 23, 2010 I run my TY on 50:1 castrol TTS no problems Quote Link to comment Share on other sites More sharing options...
bigwilly Posted November 25, 2010 Author Share Posted November 25, 2010 Many thanks all, good advice greatfully received. I've thinned out the mix to 50:1 Not had time to get out on it since though it starts and runs fine. The exhaust is leaking the black stuff as would be expected and may need cleaning though I'll only do it if I really need to as the list of mechanical jobs on the various vehicles I own is mounting high at the minute. Quote Link to comment Share on other sites More sharing options...
kuelmuel Posted December 9, 2010 Share Posted December 9, 2010 I run mine on the cheapest nastiest oil that my local bike shop stocks, mixed at 50:1. Been doing it for 4 years and it's never oiled a plug up. Quote Link to comment Share on other sites More sharing options...
bigwilly Posted December 9, 2010 Author Share Posted December 9, 2010 Cheers all. I've been out on the TY and still had a lesser issue with fouling so took the pipe off and gave it a clean. All now running sweet, just needs a new throttle cable now, and fork seals, and front shoes, and chain and sprokets. Quote Link to comment Share on other sites More sharing options...
martinjansen Posted December 12, 2010 Share Posted December 12, 2010 Hallo, I run 1:50 Putoline TT Trial Pro Scented. But I also replaced the crankshaft oil seals. That helped a lot. Greetings from overhere and lots of fun whit your TY's, Martin Quote Link to comment Share on other sites More sharing options...
dabbinbob Posted December 21, 2010 Share Posted December 21, 2010 I have run all my air cooled trials machines(James to TY mono)at 50 to 1 for 20 years with no problems. I use Maxima Super M or Silkolene synthetic. Quote Link to comment Share on other sites More sharing options...
