November 23, 201015 yr Would someone do me a favour and measure the thickness of the spacers that go between the sump guard and the frame at the front. Thanks Ross
November 24, 201015 yr The 2 aprilias i had didn't have any spacers on the sump guard, and i got both these bikes new.
November 24, 201015 yr Author Mine definatly had them before it went away for it's six month holiday, I think they should be about 6mm thick but would appreciate confirmation. Ross
November 24, 201015 yr It is common for the sump guard to "straighten out" a bit, when you come to put it back on it seems like the holes are quite a way off lining up. It's very difficult to bend the guard back to its original shape, it may be that a previous owner has made the spacers to make refitting the guard easier.
November 25, 201015 yr Author I've had the bike from almost new,its a TX240, pretty sure they were standard on this model. Thanks Ross
December 7, 201015 yr Author Mine must be worth a fortune as it appears to be the only one out there !
April 18, 201115 yr Would someone do me a favour and measure the thickness of the spacers that go between the sump guard and the frame at the front. Thanks Ross hi ross , i thought that but what i did was put the 3 back bolts in tight then lift the bike on stand the weight of the bike helps push the plate up then use a 30mm bolt to pull the plate to the frame then put a 10mm bolt in the other side , take out the 30 and put another 10 in (csk m8 allens )
April 18, 201115 yr Author hi ross , i thought that but what i did was put the 3 back bolts in tight then lift the bike on stand the weight of the bike helps push the plate up then use a 30mm bolt to pull the plate to the frame then put a 10mm bolt in the other side , take out the 30 and put another 10 in (csk m8 allens ) Thanks kirsten, mine did have them for approx 20 years, then it was stolen. When I recovered it they and many other parts were missing. I had it from (almost) new. My TX240 has a sticker on the steering head with the displacement, frame no etc. Ross
June 5, 201115 yr Author 5mm thick spacers on mine Thanks spudsdad, was beginning to think I have drempt them. Ross
October 30, 201115 yr Author Love to see some pics? Reginald Have a look at 4.50 to see one in action http://www.youtube.com/watch?v=fz8BvkZLBZ4
