bondy Posted December 15, 2010 Report Share Posted December 15, 2010 hi all has anybody had the clutch case upgrad by billet if so dose it make a big diffrance its Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 15, 2010 Report Share Posted December 15, 2010 I would have no worries about anything that Wayne at Billet does. Quote Link to comment Share on other sites More sharing options...
Guest DGShannon Posted December 15, 2010 Report Share Posted December 15, 2010 also im a bit unsure what the fuel mix i know its 50 to 1 is that 50ml? Only if you want it to be. 50:1 is a ratio. 50 parts fuel to 1 part oil. The unit of measure is whatever you want it to be, provided it is the same on both sides of the equation. 50 gallons of fuel to 1 gallon of oil 50 ounces of fuel to 1 ounce of oil 50 ml of fuel to 1 ml of oil 1 liter of fuel to 0.02 liters (20ml) of oil There are a number of calculators online, such as this on: http://www.csgnetwork.com/oilfuelcalc.html The easy way is to get a "Ratio Rite" mixing cup. Just do a Google search. Quote Link to comment Share on other sites More sharing options...
bondy Posted December 17, 2010 Author Report Share Posted December 17, 2010 Only if you want it to be. 50:1 is a ratio. 50 parts fuel to 1 part oil. The unit of measure is whatever you want it to be, provided it is the same on both sides of the equation. 50 gallons of fuel to 1 gallon of oil 50 ounces of fuel to 1 ounce of oil 50 ml of fuel to 1 ml of oil 1 liter of fuel to 0.02 liters (20ml) of oil There are a number of calculators online, such as this on: http://www.csgnetwork.com/oilfuelcalc.html The easy way is to get a "Ratio Rite" mixing cup. Just do a Google search. thanks for your help can you tell me whats the best 2 stroke oil for my sherpa 350 and weres the best place to get it cheers Quote Link to comment Share on other sites More sharing options...
swooshdave Posted December 20, 2010 Report Share Posted December 20, 2010 thanks for your help can you tell me whats the best 2 stroke oil for my sherpa 350 and weres the best place to get it cheers You'll may get a lot of answers so I'll give you mine, these things were made to run on 2 stroke oil from back in the day, so I assume that anything made nowadays is better than what they had then. No idea where to get it from. In a bind I'll grab something from NAPA but I don't think they have a ton of them in Liverpool, unless it's Liverpool, Pennsylvania. Quote Link to comment Share on other sites More sharing options...
