January 7, 201115 yr Hi all, I am a new member 95 Techno. My clutch basket keeps seizing. Any thoughts? Any help will be appreciated.
January 7, 201115 yr Need to try out the Beta threads with a good description of the problem, they should be helpful, cheers!
January 7, 201115 yr I think you are saying that your clutch is sticking when first started. Always point in a open direction and use third or 4th gear to break plates loose. Some use this method before starting,I use it after with a small wheelie.
January 7, 201115 yr The transmission fluid is not getting out of the clutch pack after shutdown. If you perform the Dan Williams clutch mod thats pinned at the top of the Beta forum and refill your transmission with 425cc of your favorite transmission lube. The problem you describe will go away unless you have another issue with your clutch.
