April 1, 201115 yr Can some body give me the details about the clutch lightening modification using a 428 chain link ? on a 200 rear kick. Any info as to how , where , and its effectiveness would be most helpfull to me . thanks.
September 10, 201412 yr Fantic Guru's I've searched the forum to find any more information on Lightening the 200 Minarelli Clutch - But I can't seem to find a definitive answer ... can any body advise me and maybe post some pictures of the finished mod ....... Or is it go down the "Apico Lightener " route Any help would be great. Cheers as always The Wobbler
September 10, 201412 yr Fantic Guru's I've searched the forum to find any more information on Lightening the 200 Minarelli Clutch - But I can't seem to find a definitive answer ... can any body advise me and maybe post some pictures of the finished mod ....... Or is it go down the "Apico Lightener " route Any help would be great. Cheers as always The Wobbler Apico works well on every bike I have fitted them to. Edited September 10, 201412 yr by b40rt
September 10, 201412 yr I will try to take a photo later but it is simple. You screw a 428 chain end plate to the hole in the clutch arm that the cable nipple fitted into. You then fit the cable and nipple into the other end of the chain end plate. It increases the leverage of the arm by the length of the chain plate and makes it slightly lighter. Worth trying as it costs FA If all is well with the clutch and cable it is fairly light although heavier than a modern hydraulic one.
September 10, 201412 yr Eddie, Thanks - I see now - I'll give it a go. B40 RT - If the link doesn't sort it that's the route i'll go - It's for a friend of mine's bike and he's not a pot hunter so no one will be bitching about it not being in the spirit !!!!! As Always The Wobbler
