Air box nut buggerd
coldcake
Right then I'm in a pickle as the nut in the air box that holds the mudgaurd has buggerd up, the nut has only a few threads left and does not take enough of the bolt.What can I do? any ideas welcomed, apart from buy new air box.
I had same problem, I used an insert-nut. They're for wood really but work fine...mines been in 18 months with no problems.
Just a bit of messing around getting the old one out.
Check this - Clickety click.
Just screw it in and make sure it sits as you want it, then wind it out again and apply a bit of glue/silicone/araldite and screw back in !
Andy.
Edited by houseape1000
One of mine failed as well. :(
The fitted nuts are made from very soft metal so it doesn't take much to bugger them up.. I just used longer thicker screws with a thicker threads, I turned them in and out abit at a time until they made their own thread in the existing nut [if that makes sense] - works a treat.
Andy.
how did you get the old one out, half the nut has broken with me.
thanks to you all for the advice.
I'm pretty sure (it was a while ago) that I decided to drill it out with a drill a little smaller than said nut, and about halfway through the nut started to spin, so I just wiggled it out a bit like a dentist removing a tooth !
I wasn't too worried about breaking the airbox as I have a mechanic friend whom uses "plasters for plastic" a kind of epoxy resin with a strip of plastic....They use it to repair cracked bumpers and it's very good stuff....but a little pricey if you don't have a friend like mine !!!
Luckily I didn't need a patch.
Andy.
