April 27, 201115 yr Hello to all. I would like to know the thread spec for a '92 Beta Zero flywheel. Need to get a puller and not sure what it is.
April 28, 201115 yr I can`t remember the size of puller, but if you have a coolant leak on the flywheel side just slow down because you have a major problem. I would not spend any money on tools or parts till you find the source of the leak. I would wait and find a puller you could use for free, and not worry about the brakes or anything else besides the coolant problem. Best of luck. Hope it is actually simple!
April 28, 201115 yr Author I can`t remember the size of puller, but if you have a coolant leak on the flywheel side just slow down because you have a major problem. I would not spend any money on tools or parts till you find the source of the leak. I would wait and find a puller you could use for free, and not worry about the brakes or anything else besides the coolant problem. Best of luck. Hope it is actually simple! I know all about what could be waiting for me under the flywheel. I just need the thread spec. Bike was cheap and I'm trying not to spend a load of money on it. Edited April 28, 201115 yr by AME
November 28, 201114 yr Hello to all. I would like to know the thread spec for a '92 Beta Zero flywheel. Need to get a puller and not sure what it is.
November 28, 201114 yr If this turns out to be a deadly problem with the water leak on your 92 Zero ,I am looking for a parts bike for my 92 Zero.I am in KELOWNA B.C. campsmith@shaw.ca thanks Rick
January 1, 201214 yr Check the diameter yourself, and pitch and whether right hand or left hand. Many euro (motoplat/bosch) magnetos were 26x1.5 R male puller. Not sure though!
