Gas gas 06 280 pro
Hey guys i've recently bought a 06 gas gas 280 pro and im loving it but i find it a little bit slugish on the first bit of the throttle wen i go to jump or wheelie any help or ideas on what would be a good idea to check out with it ?
:I've cleaned the carb out
:I've adjusted the screw on the carb both ways in and out still no joy :(
maybe too rich of a mix? I find that if i follow what gasgas says and mix 50:1 my bike hates it.. loads up all the time, etc.. which in turn would give you a 'sluggish' feel..
Is this a dellorto carb bike? If so, ck to insure it is not only clean, but the jetting is correct as many times stock jetting is far too weak, at a #30 or so pilot.
Getting up to 33-36 range can make a big difference! :rolleyes:
Slow action throttle ?
Could you elaborate a little bit more :)
Not sure which carb s in it but i'll check.
Chances are you have the Dellorto PHBL and jetting for sea level up a couple
thousand feet altitude should be in the neighborhood of:
MAIN: 118 (116 OK, NOTHING SMALLER!)
PILOT: 36 (38 OK)
NEEDLE: D36 (3rd, or 2nd CLIP POSITION DOWN FROM TOP)
FUEL SCREW: 3.5 TURNS OUT (screw on the side of the carb closest to the engine)
FLOAT HEIGHT: ARMS IN LEVEL PLANE WITH FLOAT BOWL BASE (PARALLEL)
Jon
