Primary chain
How do you judge the wear and if a replacement is neeeded on the duplex primary chain fitted to a Sherpa.
AFAIK, as long as they stay in oil, they run virtually forever.
If you really want to check it, I guess the same way you'd check a drive chain.
Try to pull it back away from the sprocket.
If you expose more than about half a tooth, the chain is shot.
FWIW I replaced a duplex primary chain on a B40 after 20 years (no expense spared)
Compared the old one with the Renolds replacement, not a mm of a differance.
Has always been run in TQF.
Good to know the duplex primary chains last & last, thank you for the replies.
