July 1, 201115 yr Afternoon all I'm one of the eternal lurkers and apologise that my first post comes across as spam but promise it isn't. Basically I'm working on a Masters degree in Urban Planning. I have to complete a dissertation and have been housebound following surgery which has made the research element nearly impossible. So I've had a change of tack and will be using the Internet for the lion's share. I'm studying noise in the countryside and am using off roading as a focal point (luckily my tutor is a keen green laner which makes life easier). If any of you could spare a few minutes to complete my survey I'd really appreciate it (you never know if I swap the Pan for an off-roader we might meet and I'll shake your hand!). I've had some discussions with members of TRF about who I'm aiming my request to. Basically in planning terms countryside is land outside of residential settlements - it doesn't really matter whether you're into trials, motocross or green laning - all responses will be useful. My link Cheers Mark
July 2, 201115 yr Filled in one for you, great idea and I'd be interested to read your results at the end.
July 2, 201115 yr Filled in one for you, great idea and I'd be interested to read your results at the end. Same.
July 2, 201115 yr You will probably get a very good (although extremely biased) response from the TBM forum. http://www.trailbikemag.com/forum/viewforum.php?f=1&sid=36e4f5d96e2765bb0e3dcbd78d2f209a
July 2, 201115 yr Author Thanks chaps I'll try and make sure that i get a PDF version of the final document (due in October) for you to have a read of. I shall get over to the TBM forum and see if they'd be interested in contributing. Although my surgery was non-motorbike induced I've been really chuffed at the level of support and encouragement I've received from all (with one sad exception) of the forums I've posted on. Thanks very much Mark
