August 27, 201114 yr Hoping someone can help me with a boot sizing question: I tried on some gaerne classic and oiled boots today. The 44's were great for width but my toes were touching the end, the 45's were way too big. I have very narrow & flat feet. Alpinestars always used to fit me quite well for enduro/mx boots so thought they may be ok but the dealer has none in stock. Are the gaerne's likely to give a little once they are bedded in? How are alpinestars for sizing, are they true to size (i've read the uk10 is a 44.5 so would be spot on and give me that little extra room. Thanks Hugh
August 28, 201114 yr Allways go OVER, cause you can't cut the toes off. Bettter to put in a cushion pad(always) and double up on the sockies if needed than the other way round! Comfy feet!
