jaumetgn Posted September 16, 2011 Share Posted September 16, 2011 I'm going for a vintage Sherpa, and I have two oportunities. Does anybody know what model ara this two bikes?? There are not the same, but I'm not capable to know if they are 199, or 199A. Or what model are both ?? I'll apreciate your help. Thank you. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 16, 2011 Share Posted September 16, 2011 (edited) They both look like M199 to me. One has earlier model sidecovers and the other has left side braking - both are common mods to M199 and M198. Neither is M199A because they are both missing the swingarm gusseting of the 199A and both have frame tubes under the motor. Edited September 16, 2011 by feetupfun Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted September 16, 2011 Share Posted September 16, 2011 look similar to me but i'm no authority. Bet Greeves will know. However the second one has definately had the rear loop chopped off. Then again you probably know that Quote Link to comment Share on other sites More sharing options...
greeves Posted September 16, 2011 Share Posted September 16, 2011 (edited) They both look 199, not 199A as they dont have the frame cut underneath the engine and the alloy protection. The second one has the frame cut in the rear just behind the seat and a older version air filter (in fact this older ones work better than the new ones, I even have one in my 198 model). This second one could even be an older model modified. To be sure just check engine and frame numbers, the last 3 numbers will thell you which model they are. The first one looks pretty original, and the tubes under the engine are not so smashed as in the second one. Aniway I am sure both are very good trials machines. Edited September 16, 2011 by Greeves Quote Link to comment Share on other sites More sharing options...
toofasttim Posted September 16, 2011 Share Posted September 16, 2011 (edited) They are both 199s. As long as it's mechanically sound I'd go for the top one because it's more original (apart from the seat of course ). Edited September 16, 2011 by TooFastTim Quote Link to comment Share on other sites More sharing options...
jaumetgn Posted September 16, 2011 Author Share Posted September 16, 2011 They are both 199s. As long as it's mechanically sound I'd go for the top one because it's more original (apart from the seat of course ). I think so. Apart from de seat,,,,...........for sure!!! Thank you very much to all the people!!! Quote Link to comment Share on other sites More sharing options...
