scorpa01 Posted September 23, 2011 Share Posted September 23, 2011 hi there my scorpa is a 01 on the swing arm it has 2x aluminium blocks with groves on it so you can move the rear wheel on the snail cams , the snail cams go up against theses but mine are getting worn now and there's not much you can do with them just wanted to know has anyone made a modification to theses , has anyone else got the same prob or even seen this prob before. ALL HELP CONSIDERED AND WONT BE WASTED!!!!!!! Quote Link to comment Share on other sites More sharing options...
copemech Posted September 24, 2011 Share Posted September 24, 2011 Possible some of the Scorpa guys can post up an idea, but I need a pic cause I cannot recall exactly what they look like, other than possibly a bit different from some others. Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted September 24, 2011 Share Posted September 24, 2011 hi there my scorpa is a 01 on the swing arm it has 2x aluminium blocks with groves on it so you can move the rear wheel on the snail cams , the snail cams go up against theses but mine are getting worn now and there's not much you can do with them just wanted to know has anyone made a modification to theses , has anyone else got the same prob or even seen this prob before. ALL HELP CONSIDERED AND WONT BE WASTED!!!!!!! Do you mean the blocks are worn or the snail cams? Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted September 24, 2011 Share Posted September 24, 2011 would it be possible to file the block down drill and tap a hole for a allen bolt to go in then the snail can go up to the allen head or file down fabricate a piece of steel the same as the block was and bolt it on Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted September 24, 2011 Share Posted September 24, 2011 would it be possible to file the block down drill and tap a hole for a allen bolt to go in then the snail can go up to the allen head or file down fabricate a piece of steel the same as the block was and bolt it on Prior to 2003, this is how they were made. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted October 3, 2011 Share Posted October 3, 2011 Little marks on the adjusters are useless. They only work in a perfect world where all machining and welding is perfect, all jigs are brand new, frames never tweak and swingarm bushings never wear.. When the sprocket teeth run right in the middle of the chain, the wheel is aligned. You could line the rear wheel exactly up to the front with string or straight edges, but then your sprockets probably wouldn't align and would wear prematurely. Maybe the World Round guys need this perfect alignment, but I'd rather preserve my chain and sprockets. Quote Link to comment Share on other sites More sharing options...
scorpa01 Posted October 6, 2011 Author Share Posted October 6, 2011 thanks for the ideas people but the alli blocks are about 15/20mm thick so cannot even tap them , i've just got a dremmal se what a can do with that lol loads of different bits in there to play with. Quote Link to comment Share on other sites More sharing options...
