Rev 4t timing
neilnh
personally i'd remove the carb, thoroughly clean it and all and check the adjustment/needle.
my experiance from the sealed cdi unit is the either work or dont.
have you check the pins on the cdi unit plug.
i know it's a rev 4t but on the evo they are more vunerable to water ingress and corrosion and that can make it run rough.
