Jumbo Carb
Hi all other swm friends
has anyone got details of which jets, slide, needle etc. should be in the carb of a 1984 Jumbo ?
Thanks Ian
Hi Ian
That will depend on whether your motor has the reeds fitted or the blanking plate.
The diagram below shows both jetting options.
(Figures in brackets are if reeds are fitted.)
Jumboreeds.jpg<img src=
Edited by MartinM
Hi Martin !
Thanks for the diagram.
I just have a question about the things listed:
Getto minimo = idle jet
pillo conico = needle jet
Valvola gas = is this the slide or main jet ?
Polverizzatore = is this the atomizer ?
Some of the things I could get translated but not all as my Italien is 0
Cheers Ian
Getto minimo = pilot jet
Spillo conico = needle
Valvola gas = slide
Polverizzatore = atomizer
Cheers
Martin
  • 7 years later...
If my interpretation is right this looks like a pilot jet of 50 ( without reeds ) but what about the main jet? looks missing from this photo? or is this the atomiser? this is smaller than a 280 engine pilot '60or 65?
Main Jet = 100.
Atomiser = emulsion tube = Needle Jet.  AS 272 (no reeds) or AS 268 (with reeds).
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/carburettor-parts/phbephb-parts/as-type-atomiser-phbh-phbe/
Needle is X2, SX 200 doesn't exist as far as I have found.
Pilot = 50 (no reeds) or 60 (with reeds).
Slide = 60 (no reeds) or 70 (with reeds).
  • 1 month later...
