b40rt Posted March 3, 2012 Share Posted March 3, 2012 (edited) If you reverse a hooked sprocket the teeth get ripped off almost instantly, if there is very slight wear and it is reversed is it OK ? ( It's not quite as worn as in following picture. ) http://www.dansmc.com/rearchain.HTM Edited March 5, 2012 by B40RT Quote Link to comment Share on other sites More sharing options...
nelly1 Posted March 3, 2012 Share Posted March 3, 2012 christ mate put some clothes on you wrong doer Quote Link to comment Share on other sites More sharing options...
copemech Posted March 4, 2012 Share Posted March 4, 2012 (edited) If you reverse a hooked sprocket the teeth get ripped off almost instantly, if there is very slight wear and it is reversed is it OK ? ( It's not quite as worn as in following picture. ) Jeez man, you lost the teef an baws!Bout time to take a pee too! Edited March 4, 2012 by copemech Quote Link to comment Share on other sites More sharing options...
ham2 Posted March 4, 2012 Share Posted March 4, 2012 Jeez B40RT are you wearing Joanna Lumley's keks now? y'can see a bit of 'Old Holburn' peeking out as well Quote Link to comment Share on other sites More sharing options...
