greeves Posted May 13, 2012 Share Posted May 13, 2012 I need to identify this rear hub and sprocket from my new project. It looks a Triumph to me but not sure, actually it´s in a old James, a quite original bike. Any idea? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 13, 2012 Share Posted May 13, 2012 (edited) Hi Javier Looks like Cub to me, 40 spokes ? Edit - spacer more to do with tyre clearance issues ? Edited May 13, 2012 by B40RT 1 Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 13, 2012 Share Posted May 13, 2012 (edited) the sprocket looks like it has been 'spaced' out with the inner ring of an older sprocket. when you get a new sproket measure it up and get someone like 'sprokets unlimited to make you one up and ask for counter sunk bolt holes so that you dont have heads stiking out etc.. Edited May 13, 2012 by totalshell 1 Quote Link to comment Share on other sites More sharing options...
tony283 Posted May 13, 2012 Share Posted May 13, 2012 Javier, Yes, its a Cub hub. You can see plenty of pictures of same on my "blog" as I'm rebuilding my Cub at the moment. The sprocket I use is made by Talon to take a 420 chain and there is 1/4" spacer that can be used. Both available from SM Products. Nice ride in the Pre 65 ! Tony 1 Quote Link to comment Share on other sites More sharing options...
bashplate Posted May 14, 2012 Share Posted May 14, 2012 nice snail cams bud Quote Link to comment Share on other sites More sharing options...
greeves Posted May 14, 2012 Author Share Posted May 14, 2012 nice snail cams bud In fact I fixed them. The bike did not had and chain came off quite frecuently. Quote Link to comment Share on other sites More sharing options...
greeves Posted May 14, 2012 Author Share Posted May 14, 2012 Javier, Yes, its a Cub hub. You can see plenty of pictures of same on my "blog" as I'm rebuilding my Cub at the moment. The sprocket I use is made by Talon to take a 420 chain and there is 1/4" spacer that can be used. Both available from SM Products. Nice ride in the Pre 65 ! Tony Hi Tony: Thanks, I had a look to your blog, nice Cub you are building, I presume the Royal Enfield comes heavier every year... I practice with a T90 Twin last year, but it´s too heavy for me, so I am actually preparing this James for next season although it´s not light at all, around 100 kilos with that very heavy frame, hubs and yokes. Quote Link to comment Share on other sites More sharing options...
greeves Posted May 14, 2012 Author Share Posted May 14, 2012 the sprocket looks like it has been 'spaced' out with the inner ring of an older sprocket. when you get a new sproket measure it up and get someone like 'sprokets unlimited to make you one up and ask for counter sunk bolt holes so that you dont have heads stiking out etc.. Thank you Totalshell, it´s spaced indeed. Quote Link to comment Share on other sites More sharing options...
