Bantam / Cub Swing-Arm Length
I lengthened mine by 1.5" and it still turns great. I used to feel it wheelied too easily up steel hills and it seems to grip better with the longer arm. Used a scarf cut for strength and inserted a tube for strength - used for 2 years and lots of drop offs/rocky sections and no problems.
Stu
Whats a scarf cut ?
Whats a scarf cut ?
Very common carpentry term, wood joinery. Google it.
Hi I am just starting to build a bsa bantam trials and I need to extend the swinging arm please could you tell me the diameters of the bushes as I dont have the wider swinging arm yet but I need to make the bushes at college befor I leave college
Matt
Matt, I have some in the garage so I will measure them later for you. They are only £8 on ebay though - are you sure you want to go to the trouble of making some?
Sorry, thought it was a bit like a paper cut !
Hi I didnt mean the brass bushes it was the ones to extend
Matt
Sorry, can’t remember what size I made the bushes .. I have an old swing arm somewhere I will try and measure it up over the weekend
The OD is 28.72mm
The ID is 23.5 to 23.79mm (slightly oval) I would guess the original tube ID was 15/16”??
It also has a ridge of braze where the tube is seem-welded
Hope this helps
