August 21, 201214 yr I bought a 44 H TY mono a few weeks back, fixed the igniton and put it in the shed while I finish a TS project, this weeckend I made a few round behind the house to find it very VERY " SLUGGISH " so I took the carb off cleaned it put it back with no improvements. I'm sure the exhaust need's a good cleane up but still I think the carb need's fixing. I have " on the shelve " a new roung slide 26 mm Mikuni ( VM type ), is it a good idea to try it on ? Or am I loosing my time, I know I have to modify the flywheel. but I have to start somewhere. Guy
August 21, 201214 yr Guy from memory the modern off-the-shelf VM26 is a physically bigger carby than the standard carby so it may not fit in the space available
August 21, 201214 yr Author Big weekend of fun comming up, 4 days with Mick Andrews ( I hope the wheater will cooperate ) first thing I'll check when I come back is the size of the VM, I had both carb 5 feet apart this saterday and did'nt think of that. Guy
August 21, 201214 yr tried a yam with a pwk 28 keihin fitted that was really good but you would need to make an adaptor for air intake.
