September 13, 201214 yr Hi, I need advice on a trial bike for a 12-13yr old. One that's fairly cheap but a good starter bike. Cheers
September 13, 201214 yr Your fairly cheap to you could be different to someone else's. Set yourself a budget and find a bike you like, then ask people's opinion/knowledge of the bike.
September 14, 201214 yr Any clean and tidy 125 or 200. As long as it is all working and safe. It will get a hammering with a youngster on it so buy on condition not price (unless you go new?)
September 15, 201214 yr There seems to be quite a lot of tidy looking 125's around for £500-£1000 which I think would b ideal. But then it depends on the boy I suppose... Has he ever ridden a bike? Has he ridden a geared bike? If the answer to either of those is no then I would be looking at something a little smaller with a semi auto box maybe.... If the answer is yes then I think (personally) a 125 would be quite ample as a starter. Anything bigger I think would chuck him off (depending on his strength etc). It's hard to say when all ya got to go on is a '12-13yr old'. I ya get what I mean.
September 16, 201214 yr I think any 12 year old would be fine on a 125 regardless of experience as they are not scary to ride. It'll teach them a lot and most importantly good technique not just using the power. Once the tech is in place you can add power later after a couple of years. This makes a 125 very cost effective indeed.
September 17, 201214 yr It looks like most bikes are the same weight and size, put a slow throttle on and use a piece of fuel hose between the carb slide and carb cap to limit power Maybe that opens up more possibilities
September 19, 201214 yr Get him a 1300 Suzuki hayabussa. That way he won't show you up in comps! Bloody nippers are so good at it nowadays, give them a trial bike for a month and before you know it they're hopping on the back wheel, doing floater turns onto 6ft walls and balancing with no hands or feet! Makes us oldies feel so inadequate for the sport!
September 19, 201214 yr Get him a 1300 Suzuki hayabussa. That way he won't show you up in comps! Bloody nippers are so good at it nowadays, give them a trial bike for a month and before you know it they're hopping on the back wheel, doing floater turns onto 6ft walls and balancing with no hands or feet! Makes us oldies feel so inadequate for the sport! :chairfall: :chairfall: that is so true! Edited September 19, 201214 yr by pindie
