September 24, 201214 yr has anyone changed the formula clutch for an ajp? if do you need to swap the hose as well or is it a straight swap?
September 25, 201214 yr I was hoping someone would have tried this... Thanks for the info Lowbrow. FWIW, thought the Formula were more or less "copies" of the AJP, so I assumed they'd be the same, but hated to mislead, so I kept my "keyboard/mouth shut" on this one.
September 25, 201214 yr Weird. The AJP brake lines (Ft & Rr) didn't fit on two formula based bikes we tried it on. The whole banjo bolt setup on the rear was different as I recall. Didnt try the clutch line.
September 25, 201214 yr Weird. The AJP brake lines (Ft & Rr) didn't fit on two formula based bikes we tried it on. The whole banjo bolt setup on the rear was different as I recall. Didnt try the clutch line. I was thinking levers ones on bars, not rear brakes, sorry. OP was talking about clutch, so..... Edited September 25, 201214 yr by sting32
September 25, 201214 yr My bad- didnt notice that. Good to know on the clutch. I was thinking levers ones on bars, not rear brakes, sorry. OP was talking about clutch, so.....
September 26, 201214 yr They (formula) not being the same connectors or banjo or whatever the difference is... Well, it just seems STUPID beyond refute... if nothing else becuase it means dealers have to have 2 types for the same friggin part in stock, and ship you the wrong one the 1st time of course.
September 27, 201214 yr Author i will let you all know tonight whether it is just a straight forward swap or not
September 27, 201214 yr Mine was a straight swap on the clutch but had to change the hose for the rear brake.
November 7, 201214 yr Formula to AJP is not a straight swop. The hose from the Formula brake does not fit the AJP master cylinder. Seems this little bit on the end is the problem: Then the banjo bolts are different sizes so you cant exchange the Master cylinder / hose / caliper. You have to replace everything. The top bolt on the Formula caliper is to short to use on the AJP caliper: So during this swop I discovered a couple of nasty surprises. This is what the clutch hose looked like when I took it off for the first time: And this piece came out of the new replacement caliper from AJP: I've learnt that you cannot trust the assembly done by the factory, or the parts supplied. Check everything, double check and check again before you fit it.
November 7, 201214 yr The rear hose will go straight into ajp calliper, it's not ideal but it does work, and I had no problems changing clutch and front brake.
