haggerthegreat Posted January 20, 2013 Share Posted January 20, 2013 i am in the middle of stripping my engine to replace the main bearings but the gear wheel on the water pump side does not want to come off,i have removed the c clip but the gear is stuck fast and dont want to force it to much any ideas colin Quote Link to comment Share on other sites More sharing options...
jandyb Posted January 20, 2013 Share Posted January 20, 2013 Try levering it out even from both sides at the same time. Be very careful to not damage the surface that you lever against. If no luck, I suppose you can leave it there until its time to knock out the crankshaft. -Jan Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted January 21, 2013 Share Posted January 21, 2013 Hagger , you may well have sorted this by now. I have the problem of gears stuck on shafts on my Merlin engines often and find the best solution is to heat the gear wheel up with a blow torch for about 5 minutes. Once it is very hot get some leverage behind it (which is even on both sides) using pry bars or something similar so you trying to pry it off. Then get someone else to knock the end of the shaft which the gear is on. The shock of the impact , the heat and the leverage are usually enough to pop the gear off. The gear should pop off. Make sure you put the nut on the end of the shaft or the gear may fly off and hit you. Protect the end of the shaft you are hitting with a nut or use a softish hammer. Quote Link to comment Share on other sites More sharing options...
haggerthegreat Posted February 3, 2013 Author Share Posted February 3, 2013 sorted, took it to my local dealer and he used a punch down the centre of the crank and a few blows with me holding it to let crank fall out off casing into my hand and no damage done think the problem may have come a bout with someone hitting the end of the crank and getting a mushroom effect while fitting the gear wheel on !! Quote Link to comment Share on other sites More sharing options...
