Leaking Tyre - Rim Tape
I would only use the soapy water to mount the rim strip. The guy in the film says the rim strip is made from a very sticky kind of rubber and amor all has the opposite effect.
They make the rim strip from sticky rubber for a reason. To keep it well in it's place after the soapy water has evaporated I presume.
But I could be wrong... :unsure:
Hmmmmmmmmmm.
Guess I will find out if the armor all has any adverse effects....................... If I remember I may post results either when it fails or yrs down the road when all is good.
  • Replies 31
  • Views 16.9k
Most Popular Posts
  • it`s not leaking spokes, spokes will never seal it`s the rim tape or more likely valve seating on the rim thats leaking. rim tapes are easy to fit, forget the gunge & do the job properly, it will
  • I have never run tubeless tires (MX bikes use tubes) but this video seems to have some good advice: http://www.youtube.com/watch?v=1sAD6l0ORVg
  • wobblenorbed
    wobblenorbed
    Silicone eats into you`re alloy rim and destroys it. Total nightmare to get off. Unless you sell the bike this method will cost you a small fortune in the long run. ( or the next owner ) Sorry to soun
Armor all is bad stuff
Spray it on a balloon and see what it does to it
