barnettbob Posted May 16, 2013 Share Posted May 16, 2013 When fitting a tubed tyre should security bolts be tightened with it over pressure or at running pressure. any thoughts ? Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 16, 2013 Share Posted May 16, 2013 I always tighten then while at about 40psi, probably doesn't make any difference. Quote Link to comment Share on other sites More sharing options...
guys Posted May 16, 2013 Share Posted May 16, 2013 "over" pressure (about 40 psi is fine) is better in my opinion. Because then you are sure the tire is properly seated. 1 Quote Link to comment Share on other sites More sharing options...
