July 15, 201313 yr Hi All, I'm now the owner of a (currently non functioning) 1997 Beta Techno. I'm working through the problems that i find, but there is a real cut and paste wiring job going on in there. Most of all i would like to get it back to standard and lose the spliced in nasties. i have a copy of the 1999 Techno manual I found online, but its such low resolution I can read any of what is written next to the wiring layouts on the diagram. If anyone could supply a better copy of a usable diagram, or point me in the right direction that would be great. Thanks All, Graham
July 16, 201313 yr With the wiring harness for the lights removed it becomes quite a cluster. Chances are that old a bike was more right than wrong being the color does not match up!
July 16, 201313 yr Author Solved! John Lampkin sent one to me, unfortunately the bike has been messed with to the point of not matching up
September 11, 20206 yr On 9/8/2020 at 9:55 PM, FastCletus said: I could use this diagram if anyone still has it Some good info here.
