September 19, 201313 yr I need to replace my footrests on tlr250.what ones fit?looking through ebay there are lots of nice alloy ones.for gas gas and other bikes.will these fit easily? or if I get steel ones I can modify with welder as I can only weld steel.
September 19, 201313 yr Genuine Honda XR footrests fit straight on and are bigger, 50616-KFB-000 and 50642-KFB-000
September 20, 201313 yr Hob, the tlr200 and tlr250 footpeg mounting bracket are very different unfortunately.
September 20, 201313 yr Author looked at xr footrests good idea being a bit bigger as standard ones are very small a job to keep my size 12 feet on.ive noticed on ebay that I can buy ones that I could modify they come flat so can be bent to suit so I could enlarge standard ones perhaps lower them as well.
September 22, 201313 yr I've used XR400 foot rests on my TLR and RTL. They are quite a bit wider than the standard ones and I got them from Off Road Only (https://www.catalyst-findit.co.uk/index.php?c=d2f5d910014f2842ada1bbc16c273aae&vat=ex&dest=prod&p=514&pid=60-200.DR). I'd probably give them a ring to make that they fit the XR400, because the ones in the picture look to have a slightly different mount.
September 24, 201313 yr i use CRF pit bike steel pegs..i cut them off, and welded them back on one inch back, one inch down..works great,.
