neilfrancis Posted October 25, 2013 Share Posted October 25, 2013 Ive got the chance of aTX311M but don't know a lot about them. I was after a air cooled mono for our clubs pre 90 route and was after a Fantic but the Aprilia has been offered me. Can I get parts for the Rotax motor ok and are there any known problems with them as this bike has a issue with the kickstarter. Thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted October 25, 2013 Share Posted October 25, 2013 (edited) Great bike (don't know why they're not more appreciated) Good engine, you won't need many parts but if you do try Martin Matthews at motoswm. Kick start shafts are the common problem, caused be continuing to use it with the knuckle slack. Pretty sure you have to split the cases to change it. Some new knuckles are still available. Complete kickstarts are scarce, and expensive. Engine's are quite noisy, a bit of piston slap is standard. Edited October 25, 2013 by b40rt Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted October 25, 2013 Share Posted October 25, 2013 or try peter night from peterborough he builds rotax cart engines Quote Link to comment Share on other sites More sharing options...
b40rt Posted October 25, 2013 Share Posted October 25, 2013 or try peter night from peterborough he builds rotax cart engines Sadly Peter has retired. Quote Link to comment Share on other sites More sharing options...
