January 6, 201412 yr I have leak on a TXT Pro 125 rad leakng on the kneck of the filler Iv'e took to my welder but he's afraid its to thin to weld can it be welded or perhaps glued? Or is it a new radiator required.
January 6, 201412 yr JB Weld is a high strength epoxy - you can apply it yourself. It is very good for all sort of alloy repairs. The industrial size is economical. ESAB do an aluminium solder / braze which can be used on thin metals that can't be welded. I have not used it myself yet but have seen good results on water pumps.
January 7, 201412 yr Tig weld it, ask your welder to do it. Really easy if you know what you`re doing. Good luck.
January 7, 201412 yr Wobblenorbed - are you a TIG welder? Filler necks are right on the limit of aluminium welding and ideally you will need a set with wave balance and high frequency for arc shaping
January 8, 201412 yr Radiator shop might be the guy to see, I think where your problem is, they might be able to braze or weld, if there is no reason or forces causing the crack to re occur? Welding with tig is probably stronger, I have a buddy that can weld Coors beer cans together, consistently... good welder like that, is what you need probably.
January 8, 201412 yr No dadof2, i'm not a TIG welder but I watched a bloke weld mine no bother at all ! Just thought I would pass on the info to try and help a fellow trialist. Only trying to be helpful. Thought that was point of this site. Apologies if it came across as anything else.
