2011 Beta 300 Evo 4T Subframe Bolts
tman427
The two main bolts that hold on the fender subframe have been good since I bought the bike. I noticed the other day one had worked its way loose, so I began to tighten the bolt only to find that it is stripped. I know that I did not over tighen the bolt to cause it to strip, but could hard hits from jumping off something cause extra stress to break the bolt loose?
Going to pull it apart next week and take a look...not sure if there is a nut welded to the back of the frame or if it is threaded into the frame. If it is the later I may need to helicoil?
Anyone else have these issues?
Thanks
Tom
I tapped mine out to the next larger size English thread and it is working fine so far. If you go this way you also need to enlarge the hole in the sub-frame so the bolt passes through it freely. In my case I have the long ride kit installed as well,
