New Forum Feature - Best Answer
As a lot of the topics posted, particularly in the bike specific forums, are questions, a new feature has been enabled. This allows a topic starter to select what they think is the "Best Answer" to their question. This is very straightforward. At the bottom right of each reply, the topic starter ONLY will see the below:
Simply click to select the reply you deem to be the best answer. Once a best answer is selected, the button text will change to "Unmark Best Answer" which can, obviously, be used to de-select a reply. Alternately, if there is an answer later that you think is even better than the one you've already chosen, then simply selecting that answer will automatically de-select your initial choice.
When a reply is marked as "best answer", that reply will then be highlighted
and the forum topic view will be updated:
This feature is not enabled across all forums e.g. Offroad Archive forums and Anything Goes forum
Feel free to play. You can't break anything with this. Anyone marking their own replies as best answer will be noted as a bit sad.
How about a "bit of a tosser" button ?
When clicked you never have to see their repetitive / boring / rude answers / posts again.
(I'm sure my posts would be censored frequently)
Click on your Username at the very top of the screen, then from the dropdown, click "Manage Ignore Prefs". You can block users there. However, if a user quotes someone you've blocked then you'd still see the quote.
