markg Posted February 21, 2014 Share Posted February 21, 2014 Hi all, I have a 199B spitting fork oil out of the vent holes in the caps. I am used to a little around the holes but these are spitting oil onto the tank and engine etc. - Any ideas how to fix this? - How do the caps come apart to clean the vent valve? Thanks! Keep your feet up! Quote Link to comment Share on other sites More sharing options...
bondy Posted February 21, 2014 Share Posted February 21, 2014 hello ive never known this to happen may be theres to much oil in the forks. should only be 180ml in each fork. to clean the fork caps take them off there should be a tiny nut on the bottom undo it be carfull theres a small spring and ball bearing inside soak them in some wd 40 then dry spoke the vent hole with some thin wire then put them together. but my gess is theres to much oil in the forks. 1 Quote Link to comment Share on other sites More sharing options...
markg Posted February 21, 2014 Author Share Posted February 21, 2014 Thanks for the reply! I changed the fork seals and put 180ml of 10w in each fork leg. I will drain and recheck. I too have never seen this before. I took the nut off the fork cap and the spring and flat disc. I can't see any ball bearing. I have swapped the caps with my other 199B so will test ride and see. Thanks again. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted February 22, 2014 Share Posted February 22, 2014 Mine used to spit oil out - it was the balls in the caps. Maybe you can find them because they are siezed in? You can get new ones if needed, about £30-40 from memory.. Quote Link to comment Share on other sites More sharing options...
hencam Posted February 22, 2014 Share Posted February 22, 2014 Thanks for the reply! I changed the fork seals and put 180ml of 10w in each fork leg. I will drain and recheck. I too have never seen this before. I took the nut off the fork cap and the spring and flat disc. I can't see any ball bearing. I have swapped the caps with my other 199B so will test ride and see. Thanks again. hi, happy to be corrected by those in the know but i believe if you have the washer and a spring then you have the earlier type, the ball and spring type have the countersunk screw in the top. the washer and spring type flap valve arrangement were fitted to the earlier bikes. however i would guess the problem is the same though regardless of type, it is probably too much oil i hope this helps Quote Link to comment Share on other sites More sharing options...
bondy Posted February 22, 2014 Share Posted February 22, 2014 Quote Link to comment Share on other sites More sharing options...
bondy Posted February 22, 2014 Share Posted February 22, 2014 hi these are 1 off my 199bs forks ive just serviced with new seals and springs and new damper parts caps are the closed typ with just the breather hole wich work well. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted February 22, 2014 Share Posted February 22, 2014 Hencam is right - its a thin washer - there are four galleries behind from memory.. Nice forks Bondy, you much be good a polishing! Quote Link to comment Share on other sites More sharing options...
bondy Posted February 22, 2014 Share Posted February 22, 2014 hello smelling thanks for the comment but cant take the praise i had them polished for me. i did polish another pair of forks witch look ok but not as good as the onces above. Quote Link to comment Share on other sites More sharing options...
bondy Posted February 22, 2014 Share Posted February 22, 2014 these are the other forks. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted February 23, 2014 Share Posted February 23, 2014 Where'd u get sm28756 polished? Was if expensive? Ta Quote Link to comment Share on other sites More sharing options...
bondy Posted February 23, 2014 Share Posted February 23, 2014 (edited) hello smelling the polishing cost me £75 by pitted fork in Luton. i had both yokes powder coated £120 this was for polished sliders and powder coating and door to door carriage. i had the forks hard chromed to. Edited February 23, 2014 by bondy Quote Link to comment Share on other sites More sharing options...
markg Posted February 23, 2014 Author Share Posted February 23, 2014 Very nice Bondy! Should look great when it's back together! Don't think the washer and spring are old style fork caps. I have 3 B's and all are the same?? Either way new caps fixed the problem. Thanks everyone! Keep your feet up! Quote Link to comment Share on other sites More sharing options...
bondy Posted February 23, 2014 Share Posted February 23, 2014 glad you got sorted. Quote Link to comment Share on other sites More sharing options...
bondy Posted March 1, 2014 Share Posted March 1, 2014 just got the 199B out for a play changed the oil hear she is Quote Link to comment Share on other sites More sharing options...
