2013 Ossa Tr280I Help Locally Please Teesside
Hi is there anyone on teesside I can meet up with to take a look at there wiring please I need to wire in a kill switch as mine has been removed for some reason thanks
Lee
One cable on the frame ( earth ) and the other on blackwhite there must be a empty plug .....
Will have a look at mine tomorrow and see if I can take a couple of pics mate. Won't be till about T time though
What about Andy metcalfe can't he help
There is a few empty plugs behind the panel thanks the pics would help. Also the previous owner has snipped the wires off the headlight I would like to know where this goes also please thanks
The kill switch should connect to a white plug near the headstock. This plug is a two pin plug with a black and a black/white cable. It should emerge from the harness with another plug that goes to the capacitor (one black cable and one red cable) approx 8" from the end of the main harness.
Also from the same point in the harness, will be a single grey cable with a female bullet connector, and a single black/yellow cable with a male bullet connector. these cables are for the dual Map switch if fitted.
The headlight should be supplied with another small harness with only two cores (red and black cables). This harness connects to a socket under the "seat" that looks like the same type plug/socket used for the kill switch at the headstock end.
Hope this is of some help
Regards Mick
Thanks mick that's a massive help, I have looked at the lanyard killswitch and it looks like one has a bullet connector and one has a ring what is the purpose of the ring?do I just cut these and join them in series with my existing wiring?
Lee
I totally forgot all about the pics sorry. Seems you have got it sussed now though ?
I'm in the garage tomorrow for sure so if you still need them no probs
Hi Wayne pics would be helpful also if that would be ok
No probs .... the bike is completely stripped just now but I can still show you the wiring.
Sorry not the best of pics .... black and white with a plug to the kill switch
Red and black on the other plug goes to the CDI located on the back of the headlight mask
All the little white square plugs are really unused and go to the instrument panel on the explorer
I THINK I'm right in saying the bullet connectors are for the duel map switch.
The wires for the lights are often removed ... it is a separate little loom that connects down at the left of the rectifier on a white plug .... sorry I forgot to take a pic of this but If you look at the pic I took whilst stripping the bike it is the plug to the very right side of the bike
Edited by wayne509
