July 6, 201412 yr probably a silly question, but i haven't gota clue, my ty sounds starved and has no topend
July 6, 201412 yr No and they were rather sluggish. You probably need to ride another one for comparison.
July 6, 201412 yr Probably a blocked exhaust.They can run like a chaff cutter,unless properly setup.Properly sorted they are crisp and will scream.
July 6, 201412 yr Author I burnt out the exhaust, cleaned anything to do with the fuel flow and air flow, still runs like crap just doesn't have that pull, gear 1 and 2 are absolutely useless there's just NO top end of the gears, on a flat i could be as fast as it will go in third, chuck it into 4th and its just got nothing, barely starts to pick up Ive rode my friends one and it absolutely flies, insane speed I cant think of anything else other than a total rebuild that will fix it
July 6, 201412 yr Are you sure the clutch is not just slipping. I remember your old posts and video. The clutch will just barely slip and will cause the problems you are having.
July 6, 201412 yr Author It does rev up, im sure its not the clutch slipping, i have a video from yesterday i made specifically for another forum after someone asked what it sounded like maxed out... This is it maxed out https://m.youtube.com/watch?v=pzmJrxPUaeg
July 7, 201412 yr Author I race mx every weekend and have a range of bikes, the ty is just perfect for my woods at home because of its agility and its not very noisy, plus you get it running quick its an absolutely awesome bike
