Montesa Cota 247
Hi Wobbler, fitted the tapered bearings today and offered up some S3 foot pegs to see how they may fit.
Edited by johnmartin247
  • Replies 125
  • Views 30.7k
Most Popular Posts
  • johnmartin247
    johnmartin247
    O.k it is a bit overdue but the painter was a perfectionist So here is the finished item.
  • ]just thought i'd put a couple of pics on now paints done managed to get a airbox off ebay this morning.a friends bringing it over on Sunday. Not had a reply over seat.but its an holiday over here s
  • Hi its seems to have taken an eternity,but the montesa is finally complete. A combination of being let down by parts suppliers,lack of motivation,because of part supplier and work meant it took far
Hi
The exhaust problem.
Cheers Steve
Some thing looks off there steve, here is two pics of my one, i seem to have a good enough space to undo the collar with out fouling the down tube.
Hope this helps.
cheers
John.
Hi John
Thanks for posting pics.
I really am stumped now,the frames straight,the engine lines up perfectly in brackets,
By the way the frame is the same as your new project,
Do you know if the round type barrel was fitted to bigger models?
could the engine have been rebuilt with a bigger barrel and piston?
Thanks Steve
Hi John
Sorry to trouble you again.
On your new frame is there a spacer in the front engine mounting bracket[right hand side looking from front to back of the bike]or are they flush like the other mountings.
On mine there is said spacer but dont know if its been added after for some reason,
If its been added after this could be whats stopping the engine moving into its correct position,
Cheers Steve
Now you've got me thinking.
I'll have another look at mine !
Hi Steve, had a look just now and there is no spacer, all flush fitting from engine mounts to frame mounts, I did wonder if some one has changed the barrel on your bike at some point.
If you take your spacer out would the engine move across enough to give you the room that you need to fit the collar? and would the rest of your mounts line up?
John.
No spacers on mine either.
John did you get the tapered bearings from in motion ??
It's looking good.
The Wobbler
Hi John
This is a pic of spacer.
someone must have welded a washer in at sometime, but no idea why.
everything looks straight,no kinks in frame or damage to bottom tubes or bash plate.
Looks like a job for the grinder and take it from there.
Ill start and post pics as restoration progresses.
Thanks for your help.
Steve
Rather than start a new thread i will just post up on this one with the rebuild projects, seen as all us cota 247 owners have a shared interest.
Here is the newly powder coated frame with yolks fitted and the new S3 pegs fitted, the pegs fitted with a little grinding to the original peg mounts and a little shaving of the alloy pegs.
Hi John
Steve
Steve, i have the same washer but it is not as thick looking as your one looks, i would be more inclined to think that your barrel has been swapped out at some point.
Yes keep posting the rebuild pics, as you will have seen i have just started mine.
The Start of the dry build
It's looking good.
The Wobbler
Yes i did along with new front and rear wheel bearings, fork oil seals and the swing arm bolt.
