chrisa Posted March 9, 2015 Share Posted March 9, 2015 Hi A couple of questions. 1. What oils are you using for the 4t engine and gearbox? 2. Getting a bit of RSI in middle knuckle area throttle hand. Was with a mate on KTM last Wednesday and no problem, but swapped onto the Montesa for 10 mins and immediately started to feel the strain again. Levers all set up for me. I'm finding that the bars are obviously much lower than the KTM's and wondering if buying some higher bars may help...anyone done this? I love the Pillow grips on the KTM and their diameter is quite a bit bigger so I'm also wondering if the narrower grips could be causing the strain?? It's annoying for sure. Chris. Quote Link to comment Share on other sites More sharing options...
rht Posted March 10, 2015 Share Posted March 10, 2015 I Chris, I use PJ1 Goldfire 10-40 engine oil and PJ1 Ultra light clutch/gear oil in gearbox on my 4RT. Sound a good idea to try larger diameter handlebar grips to help your problem, lots of riders fit higher than standard handlebars to improve their comfort on the bike. Keep your feet up enjoy trials. RHT Quote Link to comment Share on other sites More sharing options...
guys Posted March 10, 2015 Share Posted March 10, 2015 Oils: Engine: Castrol Power1 Gear box: Elf HTX 740 or GRO Gear Extreme 75W Quote Link to comment Share on other sites More sharing options...
