May 4, 201511 yr Hi Troops, looks and feels like mine hasn't been off for a while, whats the best/easiest method for freeing it up before i go ape**** with summin silly!!!! Cheers, F
May 4, 201511 yr If you mean the plastic or aluminium screw over the middle of the clutch the last very stiff one I removed I cut a piece of steel the width of the slot and ground it down to just fit in the slot and used a shifter to move it. This worked very well so I now have a steel tool for future use.Graham.
May 4, 201511 yr Author Hi Bullylover, that's exactly what i'm about to do unless someone pops up with a better option!!
May 5, 201511 yr Author Ha!!!!! Never thoght of that Bondy! Will certainly have a look at that. Moocho F
