May 28, 201511 yr Howdy Folks, there is a nice 2014 280 Jotagas for sale that I fancy. Is the power delivery like a Gasgas 280? thats to say is it more snappy than the 250 or 300. Snappy and fiery is not what I need.
May 28, 201511 yr S3 make a low compression insert for the cylinder head that softens off the power delivery, and they also make a flywheel weight for that bike. Do those two mods, and it would tame it very significantly. Or if you wanted to go further a Domino slow throttle (black tube) and a thicker base gasket would turn it into a pussycat!
May 28, 201511 yr Chris tried a 2013 280 and did like it. I think He did say It was not quite like the 280 GG. You can check for the low compression insert which is coloured gold.
May 28, 201511 yr Author Thanks a lot for the replies. Turning a Jotagas into a pussycat is an attractive thought!
