snowball Posted June 25, 2015 Share Posted June 25, 2015 (edited) Trying to put the master back together after welding done but not sure if I'm missing something as the dot4 is not pushing through in the configuration I have. Any tips. Edited June 25, 2015 by snowball Quote Link to comment Share on other sites More sharing options...
guys Posted June 25, 2015 Share Posted June 25, 2015 (edited) Maybe the welding warped or damaged the bore of the cylinder or blocked the tiny holes between the reservoir and the bore? Or maybe you just need a new repair kit? You need a new circlip anyway. And are you sure the ring belongs there? Can't remember ever seeing one in that place. Edited June 25, 2015 by guys Quote Link to comment Share on other sites More sharing options...
snowball Posted June 26, 2015 Author Share Posted June 26, 2015 Ok, thanks, will try without the ring and if not then new master it is. Quote Link to comment Share on other sites More sharing options...
arnoux Posted June 26, 2015 Share Posted June 26, 2015 Throw the ring away, and get a new circlip. The ring would hold the piston in too deep in the bore and block the transfer port. Make sure you have some free play on the lever as well or the same problem will happen. This is critical to the proper operation of AJP master cylinders. 1 Quote Link to comment Share on other sites More sharing options...
snowball Posted June 26, 2015 Author Share Posted June 26, 2015 Thank you Quote Link to comment Share on other sites More sharing options...
