Non Starter After Washing
well im finally getting somewhere, I took spark plug out and earthed it to cyl head and its sparking but not well. its got a new coil so should it spark well with this?
what else could cause a poor spark, a duff spark plug?
i wouldn't mind the first thing i did was order 2 new spark plugs but the top nipple where ngk lead attaches was different.
can i fit the new plug with a different ngk lead end or where do i get the same skinny headed plug from?
such a simple problem stopping it running i think, annoying as engine had been rebuilt last year!
cheers!
tom.
  • Replies 34
  • Views 9.4k
Most Popular Posts
  • I fitted a new coil, NGK cap and plug and it kicked up instantly first time! im over the moon! it cant have been anything to do with washing it after all! thanks everyone for your help!
  • I would start with the basics. Is fuel getting to the carb? Check the fuel tap, disconnect the fuel pipe form the carb hold the end over a bowl and turn the tap on. Does fuel come out? If not check th
  • Have you checked that you’re getting fuel as far as the needle valve? Problems I’ve encountered in the past have included, inlet filter inside the fuel tank being blocked, fuel tap being blocked, fue
iv ordered a new spark plug cap to match the plugs iv ordered with same part number.  ill update when iv tried it. thing is it always starts first kick so it must be summate and nowt.
Is there a resistor built into spark plug cap or in the spark plug?
Just unscrew the nipple from the top of the plug. It could be that there is not a brilliant connection between plug cap and HT lead. Cut it back slightly then screw the cap back on. Is there a screwed connection at the coil end?
I don't recall resistor plugs specified for Fantic so you want neither resistor.
I have known bikes with a poor looking spark that ran well for years.
Edited by fantic tom
