December 10, 201510 yr Black is ground, red is coil and green is trigger coil. Black to red is 450 to 800 ohms. Green to black is 40-80 ohms. Black to ground should be zero
December 10, 201510 yr Author hi, red one = 675 ohms but the green = 39 ohms... i change all cable new. what the NM tightening force of flywhell? thank's szymon
December 15, 201510 yr Author ok. engine is runnig! thank's for help. the main problem turned out to be the ignition coil. I used Ducati. is great!
