Yes Or No ?
has he got an online store ?
  • Replies 144
  • Views 36.7k
Most Popular Posts
  • Well again! Here's our garage! So if it's a rubbish bike (Nigel
  • Both TRS and Beta are working on EFI (hearsay from reliable sources); Beta maybe for next year. Vertigo (albeit fairly recent) and Honda (long term) are successful with EFI.  From personal experience
  • It's proven many times over that a well designed and mapped FI is superior to any fiddly carb in existance (ask ANY high-end race machine designer or race mechanic (only a village mechanic will tell y
Yes, but specialized parts aren't marked there. You must e-mail to Joa and ask if you require any OSSA parts.
thanks tsiklonaut I've just ordered the last set he has in stock
Good on you, now you owe me a beer mate  :beer:
Ahhh,so it was you that bougth it 15mim before i got his answer :lol:
Christian
Edited by christianmoller
 Dherbeymoto.fr seem to have a set of cables at half price
  • 2 weeks later...
tsiklonaut, I've started setting up my software to use the leads i have got as far as
the setting the KD diagnostic tool and KD map loader as auto transfer, which means
nothing to me, I dont suppose you know how you did it ?
Do you have any maps? If you don't have any I may send you some, be sure to let me know your ECU version, if it's ECU17 (early OSSAs) or ECU19 (later OSSAs), I have a lot of different maps for #19 version, some for #17 version too. Maps I load with the loader programs.
K-Scan program I use to reset TPS (Throttle Setting), idle speed adjustment (using tachometer), reset the 3 hour counters, different graphs etc maybe also use the leanin/riching function someday, haven't experimented with this yet myself.
My boss calls my bike the "Irish bike" because of the clovers.Lol.Happy Ossa day!bpc7pdnT9.png
They're not clovers...... they're a graphic of a cinema lamp. :banana2:
Yes, but the company does refer to itself as the clover brand on its website and, extending the theme, used to use the advertising slogan "Put a Little Luck on Your Side".
I've loaded new maps with no issue.
I've also reset TPS and even tried changing base mixture ( I noted where I started and also used an exhaust analyzer)
yes I have maps on a memory stick, but I'm a bit unsure I have
the system set up correctly, I couldnt work out how set the
should I also have icon on my desk top for the software ?
or does it start once you plug the bike into the computer ?
